vector export
droidbot1337
vector export
Post by droidbot1337 »
hi, my names dave in i just learned about XnView (yeah, about time!). so i downloaded and installed with the hope that i could convert CDR files into eps but it seems that this isnt possible. i have many CDR files that i need to convert but have yet to find a converter that does this. if possible i would appreciate any and all help. thanks in advance!
Re: vector export
Welcome to the forum, droidbot1337.
Please take a look at “Handling limited Corel format support”.
CorelDRAW.com (Gérard on Graphics » [url=http://www.coreldraw.com/blogs/gerard/archive/2008/02/26/the-coreldraw-graphics-suite-x4-viewer-is-available.aspx]The CorelDRAW Graphics Suite X4 Viewer is available[/url]) wrote:One of the requests that we've received on a regular basis has been for a CorelDRAW and Corel PHOTO-PAINT viewer. This has always been a very interesting point of discussion internally regarding how we could do this. Good news: With CorelDRAW Graphics Suite X4, there now is a viewer... and here is the detail on how to get it: Simply download and install the trial version.
The trial version of CorelDRAW Graphics Suite X4 enables you to test the full version for 15 days. Once the trial period is over, the application will automatically convert itself into a Viewer, disabling all output features such as save, print, ... You will still be able to use the product, but you won't be able to save your creations. This means that you can keep the trial on your computer if you need to view CorelDRAW and Corel PHOTO-PAINT files on a regular basis without the need to print / save these documents.
