0.60 WinXP x86: Associate tool hangs
GCRaistlin
Post by GCRaistlin »
  1. Log onto system under limited user account.
  2. Run xnview.exe (for the first time under this account) via "Run as" using admin credentials. You'll get the Startup Wizard window.
  3. Press "Run the File association(s) tool". You'll get Run As prompt - which you shouldn't really get 'cause xnview.exe has been already launched under admin account.
  4. Enter admin credentials. Assosiations tool will launch but won't appear on the screen. The only option is to kill the process.
Re: 0.60 WinXP x86: Associate tool hangs
yes right...
