Layout preference
Arpas
Layout preference
Post by Arpas »
Hi Pierre. I enjoy your software. Thanks!
Just a little thing in the UI interface.
I use the layout 7. And I have this problem:
First of all: sorry for my poor English.
When I enlarge the width of the window, the panel containing the preview (right panel) remain unchanged, and instead, the middle panel (the panel with thumbnails) enlarges. This is quite annoying because, I think, what people would usually interesting is that: when enlarge the window become enlarged preview. Do not know if I explain.
If you do not understand, let me know and I will try to explain better.
The same applies to all layouts.
It would be good:
1) that when you reduce the size of the window, the folders column and the column with thumbnails is maintained as much as possible the same size. And the preview panel change depending on the size of the window.
2) or, somehow allow the user to define which panel wants to retain its size.
Thanks for your patience in reading all this, Pierre! I hope something will serve. :D
