0.61 Restore from maximized mode issue
yilusheji
0.61 is still there
Re: 0.61 Restore from maximized mode issue
??? has been fixed
yilusheji
Which version fixes, 0.61? ? I'm using, as well as the problem does not fix! !xnview wrote:??? has been fixed
When do you have this bug?
yilusheji
Like it was after 0.34,I hope you can adjust this bug as soon as possiblexnview wrote:When do you have this bug?
Is it this BUG?
yilusheji
yes but 0.34 is goodxnview wrote:Is it this BUG?
I can't no more reproduce this bug
yilusheji
in win7 This bug Obviously, every time you restore the window, it becomes very small, but also reloads layout job,Other users estimated to have found it!xnview wrote:I can't no more reproduce this bug
yilusheji
http://newsgroup.xnview.com/viewtopic.p ... 2&start=15
http://newsgroup.xnview.com/viewtopic.p ... 2&p=111741xnview wrote:I can't no more reproduce this bug
other users with this problem have no more this bug with 0.61yilusheji wrote:in win7 This bug Obviously, every time you restore the window, it becomes very small, but also reloads layout job,Other users estimated to have found it!xnview wrote:I can't no more reproduce this bug
yilusheji
xnview wrote:other users with this problem have no more this bug with 0.61yilusheji wrote:in win7 This bug Obviously, every time you restore the window, it becomes very small, but also reloads layout job,Other users estimated to have found it!xnview wrote:I can't no more reproduce this bug
My system is win7 x64, win7 x32 I also used, the same problem, I come from China, but the problem in my several computers exist above all, hope you can check it carefully, thank you
Do you have always this bug? x32 an x64?
yilusheji
x64 alwaysxnview wrote:Do you have always this bug? x32 an x64?
