Crashes if I want to save settings in program directory
Pikashi
Use .ini file in filder "Program (XnView)" -> crash
m.Th.
Re: Crashes if I want to save settings in program directory
Do you have Write rights there? (Usually in Win7 and above you need admin rights in order to write in 'Program Files' subfolders)Pikashi wrote:Use .ini file in filder "Program (XnView)" -> crash
m. Th.
Pikashi
I think I have, I can see other files generated by XnViewMP in this folder such as XnView.db, Thumb.dbm.Th. wrote:Do you have Write rights there? (Usually in Win7 and above you need admin rights in order to write in 'Program Files' subfolders)Pikashi wrote:Use .ini file in filder "Program (XnView)" -> crash
and this is the crash report generated by windows
https://docs.google.com/file/d/0BwBBSZG ... sp=sharing
where is installed XnViewMP?
Pikashi
Installed in d:\Program Files\XnViewMP\xnview wrote:where is installed XnViewMP?
I moved xnview.ini from user directory to XvViewMP installed folder and it's ok now.
