Disable this little box
miica
Post by miica »
How do I remove this navigation like window?
During modeling, I usually open up an image and put it on the bottom right of my screen to be used as reference (I don't have a second monitor btw). Then when I scale the size of xnview window too small, this navigation window will just block my refs, it's annoying :D
Drahken
Re: Disable this little box
Post by Drahken »
This really belongs down in the MP section since it's about xnviewMP.
That aside, go tools->settings->view->view (tab)->uncheck "show pan tool"
JohnFredC
Post by JohnFredC »
You can also resize it by dragging its border.
IMO it should float anywhere I put it. Maybe in a future version.
John
miica
Post by miica »
Thanks Drahken! and sorry to post it in wrong section.
I tried resize it before too, it's a nice feature :)
