Fullscreen "Floating Views" Issues
quapurna
Post by quapurna »
Halo.
Windows7 32 bit
XnViewMP 061
1. For Settings > Fullscreen , I check both "Floating views" and "Show scrollbar".
In View mode, the "Properties" window does not appear when I move pointer to the right-edge of screen. It does appear if I UnCheck the "Show scrollbar" option.
Can I have both the scrollbar and the "Properties" window appear ?
If, since the right side of screen has already been occupied by scrollbar, so that the "Properties" should be accessed from (and appears at) the left side of screen; I do not mind.
2. I set XnViewMP to display image files only. (Settings > File List > Custom Filter). I UnChecked all options except check-boxes for "Images" (which are checked by default and can not be changed).
If I go to Fullscreen view from Browse mode, and move pointer to the top of screen, the "Float view" appears displaying thumbnails of image files only.
However, if I go to Fullscreen from View mode, the "Float view" also displays pdf icons.
Is this expected ?
Thanks.
