Open a small image with Auto Image Size set to "Fit image to desktop, all".
This resizes the program window but doesn't stretch the image itself. So you get a tiny image in a huge program window.
Is this intended behavior?
"Fit image to desktop, all" doesn't stretch small
raga
ckit
marsh
Re: "Fit image to desktop, all" doesn't stretch sm
I'm seeing the same thing. I expect it to stretch small images. 'Maximize View when Open' has no effect here. Compare this function to "Fit image to desktop, large only"- it treats images the same way, but viewer window is not expanded as much on small images.raga wrote:Open a small image with Auto Image Size set to "Fit image to desktop, all".
raga
raga
Yes, "Fit image to desktop, large only" also behaves rather strange with small images.marsh wrote:Compare this function to "Fit image to desktop, large only"- it treats images the same way, but viewer window is not expanded as much on small images.
