How Do I Backup XnViewMP?
Brans
Post by Brans »
I downloaded the update. I noticed on the site it said to backup the program before installing the new version. How do I do that?
I backed up the shell extension via right-click on an image > Options in the context menu > Backup all settings. Is this enough or do I have to backup the other part? I don't see how to do that.
Re: How Do I Backup XnViewMP?
In About dialog, you have the folder used to store all datas used by XnViewMP
Brans
Post by Brans »
Thanks. I copied the contents, made a backup folder, and placed it in another location along with the shell extension backup.
Ника
Post by Ника »
Hi all,
When you install the XnViewMP, you can choose the location for db and some other files.
One of the options is a "User" folder, the other is a "Program" folder.
I have chosen the "Prg" folder, and yet - the MP stores the files in the "User" folder?
Is it my PC or does anyone else have the same problem?
I choose the Prg folder as I have only one Windows user active, so I don't see the point of having anything in "User" folder, except to accidentally forget to back-up something... When the PC is used by multiple users - that is another story.
on newer system it's not possible to use program folder
Ника
Post by Ника »
Ok, thanks
