Many times we double-click on a file in Explorer and because that file is associated with XnViewMP, the program opens it in the Full Screen mode. (ok, there aren't many file types associated with XnView but this is another story - see http://newsgroup.xnview.com/viewtopic.p ... 12#p112712)
And we double-click on that file just because we want to convert it in another format. But we must follow a very convoluted process (exit from Full Screen - go again in View mode - Save As... etc.).
Can Pierre add the Save As... option on the toolbar and in the right-click menu in Full Screen mode?
I think it is easy and the benefits are evident.
Add Save As... in Full Screen mode
m.Th.
m. Th.
quapurna
Re: Add Save As... in Full Screen mode
Halo, m.Th.
I am sorry for not understanding what you mean.
If I set XnViewMP to start in Fullscreen, I can use the default shortcut for "Save As" (Ctrl+Shift+S).
I can also make the Tollbar appear and have the button "Save As" on the Toolbar.
As for right-click, there is no "Save As" in both Fullscreen and normal screen modes.
Did I skip something here ?
I use Windows7-32 bit
Thanks.
Thanks.
m.Th.
No, I skipped.Did I skip something here ?
Thanks a lot!
...however, I would add that button by default. Not discoverable.
m. Th.
