Halo.
Windows7-32bit
XnViewMP 0.61
I use "Crop" feature and then "Select All".
On the Crop-Bar, the value of Top, Left, Width and Height of the cropped area are not changed by the command "Select All".
To make them show the correct values, I have to drag the boundary-line of cropped-area.
Should "Select All" command set the cropped area Width and Height to the current width and height of the image, with both Top and Left is zero ?
Thanks.
The command "Select All" does not change the cropped values
quapurna
quapurna
Re: The command "Select All" does not change the cropped val
Thank you for fixing this issue.xnview wrote:Issue 16
