0.61: Weird keyboard handling - ENTER key
AmanoJyaku
Post by AmanoJyaku »
I don't know if this has already been reported
Version: 0.61 / OS: Windows 7 Pro x64
When using enter, it seems duplicate events are fired i.e.
- Pressing delete on folder -> confirmation dialog -> pressing enter does the delete but is also catched by file list, thus enters the next folder
- Pressing enter when in fullscreen view closes and re-opens immediately the fullscreen view
- Pressing enter in the rename dialog to confirm does the job, then opens the currently selected file in the browser
This is a bit annoying ;)
CreativeWorld
Re: Weird keyboard handling - ENTER key
Post by CreativeWorld »
Do you have the keyboard repeat delay set to short or maybe
your pressing the enter key slightly longer than most people?
Here's a page describing how to change the repeat delay,
try moving the slider to the left so there's a longer delay,
before the key starts repeating.
http://windows7themes.net/productivity- ... -rate.html
Im only able to reproduce the things you mentioned if i
hold down the enter key for more than 1 second,
then the enter key starts repeating as if i was pressing it repeatedly.
I can't reproduce this bug
