Unnatural Paste Operation
m.Th.
Post by m.Th. »
The program should look at paste operation in the Thumbs pane if the popup menu is on a folder and paste the files IN it not NEXT to it.
Go at c:\foo and select the subfolder 'bar' - right click -> 'Cut'.
Go at x:\baz and in the Thumbs pane select the folder 'Blah' - right click on it -> 'Paste'
Expected: The folder 'x:\baz\blah\bar' is created and all the photos are moved in.
Actual: The folder 'x:\baz\bar' is created and all the photos are moved in.
m. Th.
