TC-plugins libraries…
:arrow: Pierre
:) Hello Pierre !
- The libraries used as plugins in Total Commander have four extensions :
• *.wlx
• *.wcx
• *.wfx
• *.wdx
- Currently, XnView doesn't recognize these extensions, although they are simply DLLs.
- Hence, it's impossible to view or save icons which are embedded inside…
- Please, could you enable these extensions in a next version ? Thank you to consider this issue.
:mrgreen: Kind regards,
ouistiti
Post by ouistiti »
Hello Pierre,
I support this request. It should be useful to view embedded icons directly, carrying the files on the XnView icon on the button-bar in TC via Drag & Drop.
Friendly,
Paul
1,77245385090552...
