[0.61] Linux - Smaller thumb
Roumano
Post by Roumano »
with the new version, sometimes, thumb are re-generete smaller for exemple when i add a categories for this image.
If i change the directory & come back on the previous directory, the thumb get is normal size.
Roumano
Re: [0.61] Linux - Smaller thumb
Post by Roumano »
It's also regenerete with the corret size if i scrool down/or scrool up
It seems that the thumbnail size in DB is slower than thumbnail size in browser view, right?
Roumano
Post by Roumano »
I don't have enable the "enable thumbnail caching"
could you send me the picture file? Which thumbnail size do you use?
So no thumbnail caching?
And always after adding a category to this file, you have the problem?
