Hello
Am I doing something wrong here...
When I'm editing IPTC values of multiple files ... and I CHANGE information already entered before, I click "save all" but only the first file is receiving the information changed... If i change it "file by file" with "save" command the info is updated like i want...
p.s. This only happens when the files already have previous information... If the values are blanked (first edit value) the "save all" command works perfectly
Thanks
IPTC Save All - Updating Info
Re: IPTC Save All - Updating Info
I can't reproduce, do you have a file to reproduce?
What do you have in IPTC>Options?
jbileu
Sorry....!!! My fault... Lack of attention....
Obviously we must UNCHECK "Replace only if original value is empty"
Tank you
Tank you
