Batch convert output to relative path
pough
Post by pough »
RE: XnViewMP 0.61 win64
In the old version (xnview) I was able to use "./subfolder" to specify a relative path for batch conversion output into subfolders of the images being converted. This doesn't seem to work in XnViewMP. I haven't been able to find any information about this so I don't know if it's on purpose, an omission, or requires the use of a different convention. I've found some very old posts that mention relative paths and so I've tried "%/subfolder" and "$/subfolder" and even "{Directory}/subfolder" - all of which create new folders on my Desktop.
Apologies if this is the wrong forum for asking about this. I think that technically it has to do with XnConvert but I'm primarily using XnViewMP.
oops66
Re: Batch convert output to relative path
Post by oops66 »
...And into the menu, for example:
Filename:
/4-emails_{Folder name}/{Filename}
( *v checked)
v Keep folder structure
v Keep original date/time attributes
v Preserve Metadata
v Preserve color profile
m.Th.
Post by m.Th. »
oops66 wrote:...And into the menu, for example:
Filename:
( *v checked)
v Preserve Metadata
Or more easier: For each edit box support a simple macro engine which will replace the macros between '<' and '>' with their actual value before passing the edit box value to the actual processing algorithm. I choose to have the macros between angled brackets because these are illegal characters for paths/filenames.
The macro engine doesn't need to be optimized at all - it can be something like:
function myMacroEngine(aString: string): string;
begin
   Result:=StringReplaceAll(aString, '<DirName>', GetDirName); //-- needs to be CASE INSENSITIVE!
   Result:=StringReplaceAll(Result, '<FileName>', GetFileName);
...etc...
end;
I think that Pierre has something similar or even better for Metadata -> labels, hints. ;-)
m. Th.
pough
Post by pough »
This seems to be working now (I can use just "800" in the output folder) so I thought I would say thank you. Thank you!
