bug: Cannot clowse browser tab with clicks
Drahken
Post by Drahken »
While the individual image tabs can be closed with either middle clicks or double clicks (assuming you have your options set to allow each), the browser tab cannot. The only way to close the browser tab once it's opened is via the "X" close button, which of course requires having the close buttons enabled. If you have the close buttons disabled, there is no way to close the browser tab.
I am using MP 0.60.
CreativeWorld
Re: bug: Cannot clowse browser tab with clicks
Post by CreativeWorld »
confirmed in v0.61 on linux mint 15 32bit
Middle or double click on the browser tab has no effect,
it would be of greater consistency to have the same behaviour on all tabs.
ctrl + w also works to close the browser tab.
Drahken
Post by Drahken »
CreativeWorld wrote: ctrl + w also works to close the browser tab.
Good tip, beats the hell out of enabling the button, then re-disabling it. Thanks.
