Hi!
Is there any way to speed up image loading when launched from other app? Without closing XNView it takes much more time to open a new image. And going back and forward with hot keys while IN the Viewer is almost instant.
Thank you!
Image loading speeds in Viewer vs launching from other app
itsskin
itsskin
Re: Image loading speeds in Viewer vs launching from other a
MacOS 10.7.5xnview wrote:on which OS?
Do you have the same delay when your XnView with an empty tab?
itsskin
Yesxnview wrote:Do you have the same delay when your XnView with an empty tab?
So it seems that it's the time to start the app
Do you have an old Mac?
