v2.40 Reports... starting with borland cbuilder stuff
MaierMan
Post by MaierMan »
Hi Pierre,
first thx for releasing v2.40.
Im currently doing my test with it :D
We talked some time ago in another topic about Borland CBuilder "incompatiblities" when it comes to #ifdef WIN32
Seems I forgot to mention another incompatiblity in libgfle.h
Using the same "scheme" you've taken for replacing the other ifdefs #ifdefs:
libgfle.h, 131 is:
#ifdef WIN32
and should be
#if defined( WIN32 ) || defined ( __BORLANDC__ )
Sorry for causing trouble :p
Re: v2.40 Reports... starting with borland cbuilder stuff
MaierMan wrote:Hi Pierre,
libgfle.h, 131 is:
#ifdef WIN32
and should be
Ok, thanks
Anamku
Post by Anamku »
Hi All,
A query is the library functional while using only win64 and not win32.
Anam
