xnviewmp: file not found
Ammammata
Post by Ammammata »
I'm using Lubuntu 12.04 LTS 64-bit and xnviewmp 0.61 64-bit as well
When I right click on a image file and select xnviewmp to open it I get the a.m. error message ("file not found")
But if I start xnviewmp, browse to the folder and selet the image, it's properly shown in the program
Last, if I set xnviewmp as default viewer and doubleclick the image file I get always the same error message :(
Tested on two different computer with same o.s.
What can I do?
p.s.
how can I make a search in the forun for the word "not"?
if I write "file not found" it searches for "+file -found" :shock:
Ammammata
Re: xnviewmp: file not found
Post by Ammammata »
adding a note:
I'm using the italian version that says "File non trovato", "File not found" in english
The error message could be also "No such file"
and if you start xnviewmp with an argument from console, it works?
Drahken
Post by Drahken »
Ammammata wrote:
p.s.
Put a plus in front of not. file +not found That tells the forum that "not" is being used as a search term.
gmh2000
Post by gmh2000 »
xnview wrote:and if you start xnviewmp with an argument from console, it works?
I'm on lubuntu-14.04-desktop-amd64. I got the same error.
However, if I run from the console:
xnview /home/ch/Desktop/照片/IMG_20140503_162629.jpg
(or)
It DOES works.
How to fix it to open it by default with double click (or right click + XnView Multi Platform)? The file browser is: PCManFM 1.2.0
gmh2000
Post by gmh2000 »
I have solved the problem doing the following:
edit (with "sudo") the following file:
/usr/share/applications/XnView.desktop
Change:
Exec=xnview %U
By:
Exec=xnview %f
This solution is based on: https://bugs.debian.org/cgi-bin/bugrepo ... bug=737704
In that case the same problem was with xarchive and PCManFM. Therefore, it seems a bug of PCManFM.
