I found if I zoom out a tif image, the quality is quite bad as it doen't do the resampling.
0.61: Poor tif quality
3dot
m.Th.
Re: poor tif quality
3dot wrote:Hi,
Tools | Settings | View | High Zoom Quality
What value do you have there?
m. Th.
3dot
Thank you. I will test after I back to office:)
3dot
The setting is "reduce", I tried different setting but the result is same and only happened on .tif image, .jpg is fine.
Below image (both zoom out to 56%) show the difference of rendering.
could you send me the file?
3dot
Hi, here it is. I guess it might be problem of windows xp, I will try it at home again and let you know the result.
https://www.dropbox.com/s/j3d1d4d4hiadh ... 210030.tif
3dot
same case on windows 7 environment.
ok the problem occurs with 1bit file...
bsteph10
Hello, is there any progress on fixing the tiff quality in XnViewMP?
Thanks,
Bryan
Thanks,
Bryan
will be fixed in next version
