I couldn´t find a better way to name the subject. The problem is with the file information you can display in the top left corner when viewing an image in full screen.
- Display image in full screen showing the file information including file size
- Resize the image
- Save
- Press F5
Result: The new file size is displayed on top of the old file size, both are visible at the same time (more or less).
XnView 2.04, Win 7 SP1
File information overlay
larsen
Re: File information overlay
Still buggy in 2.25
sorry but i can't reproduce...
- Forum Librarian
Confirmedlarsen wrote:- Display image in full screen showing the file information including file size
- Resize the image
- Save
- Press F5
Steps to reproduce:
- Download and open Breaking-Bad-Heisenberg.jpg.
- Switch to fullscreen display (F11).
- Enable the info overlay (I).
- Resize the image (Shift+S) to 320×180 pixels.
- Save the resized image (Ctrl+S).
- Refresh fullscreen display (F5).
[color=green]xnview.ini[/color] wrote:Code: Select all
[Browser] UseBytes=1 [Fullscreen] FontBold=1 FontCharSet=0 FontHeight=-48 FontItalic=0 FontName=Verdana IsTransparent=0 Opacity=128 Position=0 TextBackColor=16711935 TextColor=16777215 [View] Text=|| <Size> bytes ||
- Forum Librarian
Seems to be fixed in v2.30/2.31
