Full screen - wrong data in the information pane
B.Douille
Post by B.Douille »
In some conditions, the information pane that can appear on the right of the full screen shows information from another image.
This happens when I switch from explorer/thumbnails to full screen, back to explorer to select another picture and switch to full screen again.
The more obvious are the EXIF tab or the ExifTool tab that present the wrong camera model. The property tab information is wrong as well: filename but I've seen once the camera model and picture date being right while the file name and other info was wrong in this tab.
Go forward to the next picture an backward restores the right data.
BD
Daniel, happy user for 20 years, to manage photo and videos and share them in slideshows (Windows 11, Linux Ubuntu and Android)
Re: Full screen - wrong data in the information pane
how to reproduce?
CreativeWorld
Post by CreativeWorld »
Here's how i reproduced the problem in xnview mp v0.61 on linux mint 15 32bit:
After starting xnview mp,
open an image in fullscreen,
move the cursor to the right edge to show the properties,
take note of the info for example filename and size,
now close fullscreen,
open another image in fullscreen,
open the right edge properties again,
the properties still show the first image's info.
The fullscreen properties update if one changes
to another image while in the fullscreen viewer.
The fullscreen properties panel seams to be remembering the info of the last viewed image.
The tools/settings/fullscreen/show info (top-left corner in the fullscreen viewer),
updates with every new image.
B.Douille
Post by B.Douille »
I checked with another machine, same issue. Both are running Windows Seven.
I cleaned the database to see if the issue comes from there but no improvement.
BD
