I'm using the Mac-version of XnViewMP.
I tried to use the batch conversion tool and couldn't find it.
Doesn't it exist on Mac or do I have to install something additional?
Or is it hidden perfectly ? :-)
Regards, Hago
Batch konversion tool in the Mac-Version
Re: Batch konversion tool in the Mac-Version
In the Browser but not in the viewer:Or is it hidden perfectly ?
Tools | Batch convert...
The Mac version should be the same as the Windows version above AFAIK.
hago
Thank you, I found it.
Regards, Hago
Regards, Hago
