I've installed xnviewMP 0.61 for i386 debian and I can see some improvements, and from your changelog that's a lot of work you've done, Pierre!
I've noticed again however,
1. when I create a new folder in browser, using the new folder icon button, the folder tree does not update with a new sub-folder as I would expect it to...
which means new folders can only be navigated to through Browser, not through folder tree, UNTIL Xnview is restarted.
Any one else see this bug? can it be fixed next time round?
2. Also, the new folder will not delete! hey what's up? (with any method I try)
cheers
foldertree does not update when create new folder in browser
orbspider
m.Th.
Re: foldertree does not update when create new folder in bro
Cannot reproduce on Windows.
m. Th.
