Is there a way to adjust Brightness/Contrast/Gamma/Balance for SELECTION ONLY?
Image > Adjust > Brightness/Contrast/Gamma/Balance does that for the whole image.
Filters work for selection but I haven't found any suitable Filter.
Regards
Bence
Adjust Brightness/Contrast/Gamma/Balance for SELECTION ONLY
btakacs
Re: Adjusti Brightness/Contrast/Gamma/Balance for SELECTION
It works for me...
You need to check 'Apply to image' in the Image > Adjust window to preview the effect.
Edit:
When a selection has been made, the Before and After displays in the Image > Adjust window do misleadingly show the change as being applied to the whole image, but the operation is only in fact applied to the selection when OK is clicked.
Edit:
btakacs
For me it's not: it applies the changes to the whole image, not the selection only.
Additionally if I adjust Hue/Lightness/Saturation, then it additionally TURNS OFF the transparency of the PNG.
I use XnView 2.0.4 on Windows 7.
I'm using XnView 2.04 on Windows 7 too and this is what I see:
Selection with the following settings:
And the result:
Edit:
You are making the selection before clicking on Image > Adjust > Brightness... ?
And the result:
Edit:
btakacs
Ok, here is the result of my investigations:
This function works fine until I make the image paletted (Image > Convert to colours).
On paletted images that happens:
...and yes: I first made the selection and then did the adjustments.
btakacs
So it is working this way:
- Converting the image to 32 bits (Image > 32 Bits)
- Adjust the selection
- Converting back to Palette (Image > Convert to Colours)
- Setting the transparent colour again (Image > Edit Palette > (Select colour)+ (Enable transparency) then (OK) )
Actually it was my fault: this is the issue of not knowing the underlying basic concepts.
Thanks to Batti for the Help
