Did not find something matching my/this case. (move, or linkup, if there is.)
Something that has been plaguing XnView (on my side) for a relative long time. (Time > year(s))
Probably some odd exception related to local hardware and/or drivers. (kinda annoying none the less.)
Case:
XnView Window: image view.
Function: browsing buttons, the left and right arrows on the toolbar.
Action: Clicking both the left and right mouse button (on one of those browse buttons).
- I don't need to click both mouse buttons at the exact same time. Clicking, and holding, one mouse button. And than clicking the other mouse button will do it to (on my side at least).
Result: XnView stops responding. (-> Killing XnView process to get rid of it.)
- It kinda feels like its trying to do two things that never* finish. (* well, outside my 'test' waiting tolerance. ~1 minute.)
Local data:
XnView: 2.4.0.0
OS: Win.XP.Pro.32bits.
Mouse driver: Microsoft - HID compliant mouse - 5.1.2600.0 - (2001.07.01)
Mouse type: USB - Led/laser - HP/Compact - 3 button - mouse wheel.
Computer: Compaq dc7100 Small Form Factor PC
PS: "You do not have to register to place posts in this forum." -> Rules and Guidelines
If you still can ... I was not able to find where and/or how. (outdated (mis)information I'm sure.)
Lockup, Image view, Browse, Left & Right mouse.
MvGulik
- Forum Librarian
Re: Lockup, Image view, Browse, Left & Right mouse.
This bug is supposed to be fixedMvGulik wrote:Did not find something matching my/this case. (move, or linkup, if there is.)
Thank you, MvGulikMvGulik wrote:PS: "You do not have to register to place posts in this forum." -> Rules and Guidelines
Welcome to the forum!
MvGulik
Aha.XnTriq wrote:This bug is supposed to be fixedMvGulik wrote:Did not find something matching my/this case. (move, or linkup, if there is.)![]()
But ... is also contains a trailing
(2010)helmut wrote:In XnView 1.97 the problem occurs, again.
This
working workaround will come in handy.Once you focus a window of any another application and then return to XnView it works, again.
MvGulik
Yep. That working workaround did come in handy. Although the fact that I'm currently running XnView (classic) version 2.12 seem a bit odd.
Just run into a aPNG(Animated png) that crashes XnView (classic) ... But, well, as its a invalid aPNG its of course a low priority type of issue (kinda like this mouse issue.). ... So I will not make XnView Dev's wast there time on it.
PS: Is there a other place where bugs (the XnView kind) have a better resolution habit ?
