Hello.
* XnViewMP is not displaying png.
* I can display correctly with other graphic viewers, i.e. gthumb, geeqie.
* Viewing at 100 percent will display the png corectly.
Details;
File size 372.84 KiB (381,792)
Format Portable Network Graphics
Width 2513
Height 3263
# of bits 8
Color model RGB
DPI 300 x 300
Print size 21.28x27.63 cm, 8.38x10.88 inches
Compression ZIP
Images/frames count 1
Origin Top-Left
ExifTool
ExifTool Version Number 8.63
File
Directory /home/dtangmo/Desktop/2010-ASP-Return/Cover
File Size 373 kB
File Modification Date/Time 2013:08:20 13:04:12-07:00
File Permissions rw-r--r--
File Type PNG
MIME Type image/png
PNG
Image Width 2513
Image Height 3263
Bit Depth 8
Color Type Palette
Compression Deflate/Inflate
Filter Adaptive
Interlace Noninterlaced
Palette (Binary data 768 bytes, use -b option to extract)
Pixels Per Unit X 11811
Pixels Per Unit Y 11811
Pixel Units Meters
Composite
Image Size 2513x3263
Any ideas ?
Thank you
0.61 Linux 64bit: PNG not displaying
Re: PNG not displaying , MP 0.61 Linux 64 bit.
please send me the file?
Katamara
OK Pierre.
To which e-mail adddress ?
contact at xnview dot com
Sjet
Re: 0.61 Linux 64bit: PNG not displaying
I' having the same problem.
Here is a .png unscaled: http://i.imgur.com/q4xdic5.png
And how it renders when scaled: http://i.imgur.com/nkrqNeL.png
And a .gif unscaled: http://i.imgur.com/YKTbf9l.png
And scaled: http://i.imgur.com/CmXlRAZ.png
I attached an archive with the images that fail to scale.
