The cutting tool does not work with keyboard shortcuts
michaauskiel
Post by michaauskiel »
The cutting tool does not work with keyboard shortcuts :| To select the tool works well with the keyboard shortcuts. But then it does not apply my crop with an shortcut. Iḿ using Ubuntu 64.bit.
Thanks
michael
Re: The cutting tool does not work with keyboard shortcuts
you means that Crtl+X doesn't work?
michaauskiel
Yes, but i changed Crtl+X to just x.
CreativeWorld
Post by CreativeWorld »
If your talking about the Edit > Crop, command,
(it removes everything outside the current selection,
or if there is no selection the crop toolbar shows up
and one can finetune the position, size and aspect ratio
of the selection before cropping),
the keyboard shortcut for the crop command in
xnview mp v0.61 and xnview 2.04 is
shift + x
If your talking about the Edit > Cut, command
(it copies then deletes the current selection),
the keyboard shortcut for the cut command in
pretty much every application is
ctrl + x
The Edit > Cut or ctrl + x, command does not
work in xnview mp v0.61.
There is a recent thread about it here:
Ctrl+X not available for cutting from picture
