Effects
badapplebuddy
Effects
I enjoy the software and appreciate it being freeware for opening and exporting RAW image files. However none of the effects work for me. The most they do is alter brightness and saturation in images and add a lot of digital noise to the images , but never the intended effect. I'm running windows 7 64bit on a hp pavillion g6. I was just curious if it was on my end or the apps end. I tried unintstalling and reinstalling ,as well as converting the raws to every format possible. Thanking you in advance, Alan.
Re: Effects
Perhaps the RAW file has noise, and changing brightness show it
XnView import RAW as 8bits component
