Open width.../Associated editor (F4) is dose not work on XnViewMP 0.61.
Thank you.
Associated editor
CreativeWorld
Re: Associated editor
Tolken, when reporting problems it helps if you give as much information as possible,
in addition to the version of the application as you stated in your post,
the version your operating system, and describing what happened, if anything,
when you chose the menu command and/or performed the action that caused the problem,
and what you have tried to pinpoint the problem.
Here's what happens when i run the command
file > open with > associated program (F3)
Tested with xnview mp v0.61 in linux mint 15 cinnamon 32bit
When i choose
the image opens with the application i have associated with opening
images of the same type as the image i currently have open.
By default i open images with xnview mp
and when i choose
file > open with > associated program,
another xnview mp window opens with the image i had open.
When i change the system settings to open images with for example
EOG (Eye of Gnome)
then
opens the image with EOG.
After adding applications to
file > open with > configure programs...
for example
eog (eye of gnome)
gthumb
and
gimp
and choosing one of them from the list
file > open with > [application name]
the image opens with the selected application.
The hotkeys also work fine for opening with the associated application.
F3 = associated program
alt + 1 = the first application added to the (configure programs...) list
alt + 2 = the next application
and so on.
When i choose
and when i choose
EOG (Eye of Gnome)
then
for example
eog (eye of gnome)
gthumb
and
gimp
and so on.
Tolken
hello,
command: Tools > Open with > associated editor (F4)
its hotkey (F4) also dose not work.
my system is xnview mp v0.61 in windows xp sp3 32bit.
and about command "thumbnails size", please, see the attachments.
CreativeWorld
tolken, a tip for next time from The rules and guidelines
- One problem/question per post.
Please start one topic per problem/question. This will make answering easier.
Now to the thumbnail size/text problem.
It also happens in xnview mp v0.61 on linux mint 15 cinnamon 32bit.
When one changes the thumbnail size
from the menu
view > thumbnails size > (width x height)
or from the thumbnails size toolbar button,
then the appearance of the thumbnails revert back to
view > view as > thumbnail + label
even though the view > view as
menu still shows a dot next to the previously chosen setting.
It seams to only apply to the first 2 view > view as settings
thumbnails
and
thumbnails + filename
The view as setting does not revert back to
thumbnail + label
if one changes thumbnail size using the slider to the top right under Quick search.
There seams to be a mismatch between
and the
thumbnail size slider (top right).
If one moves the slider to the left most position
the tooltip shows 32
if one now selects
view > thumbnails size > 96x72
the thumbnails are almost the same size,
there's less space above and below the thumbnail,
but the slider has jumped to the right 12 pixels,
if one now moves the slider one pixel to the
right or left then back one pixel then the tool tip says 96,
but the thumbnail size is much larger.
from the menu
thumbnails
and
thumbnail + label
and the
if one now selects
