Error message when trying to resize images
tikka55
Hi! A new user here. I have no success in getting the app to resize the images. It keeps showing errors no matter how many settings I've tried. It worked the first time and then I couldn't get it to work afterwards. Any pointers would be appreciated!
Re: Error message when trying to resize images
Could you post the command line you're using?
And as a check does entering:
at the command prompt list the help file, as confirmation that NConvert is installed successfully?
nconvert -helpat the command prompt list the help file, as confirmation that NConvert is installed successfully?
