0.61: Exporting a picture
AndyK
Post by AndyK »
When I'm viewing a screenshot, cropping it and then want to export it (ctrl+alt+s), I don't get displayed any file in the folder, even if there are plenty of the same file type I selected.
In XnView 2.04 there are always displayed files of the same type when I use the export dialog.
PS:
Another little two:
* the button to export the pic is labeled "save..." instead of "export...".
* the button has no Accelerator (i.E: Alt+s for save, or Alt+e for export).
Re: [0.61] exporting a picture
Right
Re: 0.61: Exporting a picture
