I ran through my pictures, full screen, mouse scroll for next picture.
Then a .html file comes up. XnViewMP loads it and starts rendering with a few .js scrippt errors.
Now, the .js script errors are not the problem, they are expected from a wget download.
But how can I disable that xnview even trying to render html files? I can't find the option.
Or do I have to rename/delete a .dll in the plugins directory, namely webp.dll ?
Disable html render in viewer (not browser) - How?
Jou
Gaming in 4k / 6k / 8k / 15k / 16k? Yes! https://joumxyzptlk.de
Re: Disable html render in viewer (not browser) - How?
In Option>Filelist>Custom filter, you can add exclude it
Jou
Works!
Thank you!
Thank you!
