B&W images stored in pdf are too big
Michel-nk
Post by Michel-nk »
When i save black and white image in PDF-format, xnview stores them in this manner:
/Type /XObject
/Subtype /Image
/Name /Im0
/Filter [ /ASCII85Decode ] :?
/Width XXXX
/Height YYYY
/ColorSpace 11 0 R
/BitsPerComponent 8
/Length 10 0 R
stream
!<<*!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8
W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!
s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W
-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s
8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-!s8W-
and pdf's size becomes ... very very very monstrous. :x
But after converting source to grey, pdf becomes normal size.
Dear Author! Please, provide possibility to automatic(implicit) B&W to grey-scale image converting before putting it in PDF. Or fully change storage method for B&W images in PDF.
Thank you!
Re: B&W images stored in pdf are too big
In greyscale, it's smaller because you use JPEG compression, right?
Michel-nk
Post by Michel-nk »
xnview wrote:In greyscale, it's smaller because you use JPEG compression, right?
Yes, right. But i can't apply this compression method to B&W-images when store them in PDF. How can i do this?
Yes, the only way is to convert them in greyscale before
Black and white images saved as TIFFs with Fax compression can be very small -- much smaller than a grayscale JPEG -- and when a PDF file is created from a TIFF image, Fax is one of the compression option available.
I think you could be quite surprised at the small file sizes that result when a black and white image is saved as a TIFF, or a TIFF image saved as a PDF, when Fax compression is selected. Fax is also lossless compression, unlike JPEG, so even when the file size is very small there is no loss of quality.
