Error when printing
RedFX
Error when printing
Post by RedFX »
Hello
Open a file (*. Tif). Then in the menu File-Print. And Xnview an error and closes.
https://www.dropbox.com/s/oeo8dqh1u5imfbt/1.TIF
Windows XP SP3, XnView v.2.04
Re: Error when printing
Sorry but i have no error, perhaps no enough free memory
RedFX
Post by RedFX »
Yes, you are right, the program closes after printing a certain size. Tried to print in other programs, it's okay. It can not be fixed in XnView? (Show error)
Your TIFF file provided via dropbox has 29529 x 13869 pixels, black & white. The image is empty (white). Correct?
If yes, your image has ~ 409 Mega pixels. Assuming that XnView uses RGB colour model internally, it will use 3 Bytes per Pixel resulting in 1171 MB of memory. That's quite a bit but I wouldn't expect that this size causes trouble, already. But I don't know anything about the internals of XnView.
