0.61: How to crash XnViewMP in few seconds
m.Th.
Post by m.Th. »
How to crash XnViewMP in few seconds. The critical part here is "in few seconds".
How to reproduce:
Have a (sub)root folder (c:\myRoot) with many subfolders (c:\myRoot\sFolder1, c:\myRoot\sFolder2 etc.) and images in it from which at least some of them are not yet 'seen' by XnViewMP.
Perhaps is better for the program to have the default setting to display 4 thumbs for each folder.
Browse the said root folder (c:\myRoot\). The background thread which builds/generates the thumbnails will detect the new folders/items and will start to generate thumbnails.
If the thread isn't finished yet and we'll try to enter in a subfolder (eg. c:\myRoot\foo ) by double-clicking on the folder in the thumbnails pane the program will crash. But for this the user must be quick: double-click on the desired subfolder in the very first few seconds in order to catch the building process. Unfortunately, there are enough users which are very quick... :)
m. Th.
Re: MP 0.61 - How to crash XnViewMP in few seconds
After deleting all cached thumbnails I've tried to crash XnView MP 0.61 by clicking around in the folders very quickly but failed: No crash. The only crash occured with a folder with a video. The video played and when clicking further on, XnView crashed. Do your folders contain videos?
m.Th.
Post by m.Th. »
helmut wrote:After deleting all cached thumbnails I've tried to crash XnView MP 0.61 by clicking around in the folders very quickly but failed: No crash. The only crash occured with a folder with a video. The video played and when clicking further on, XnView crashed. Do your folders contain videos?
Nope.
...or very rarely.
I have 300-600-900 .CR2 (Canon RAW) files ~ 25-35 MB each.
I suspect that the problem is centered around a certain state(s) WRT background thumbnails building thread. I suspect that the same applies to some bugs related to ODM (On-Disk Management) engine: Move files bugs, Rename quirks etc.
IMHO when the ODM kicks in, the Thumbnails Builder should be either:
...suspended in a stable state but this can lead to complications because the ODM can change its working environment by removing (ok, moving) directories around, renaming etc.. Also here, Pierre needs to be sure that the Thumbnails Builder IS Atomic (IOW, nobody from outside can catch it in an internal transformation).
or
...(perhaps, better) canceled. Also, here atomicity must be preserved but the things are simpler.
m. Th.
I'm not able to reproduce it :(
PS: The thumbnail thread is stopped when you change the folder
BloodyRain2k
Post by BloodyRain2k »
I had a related problem with this: while the thread is still generating the thumbnails I crashed it multiple times by categorizing an image.
So to be clear about it, it was still generating thumbs and I went to an image that was already thumbed and tried to categorize it and bam, it crashed. And that every time. Took me a while to notice what when wrong there because obviously after the thumbing is finished categorizing works fine.
Debian 12 x64 - XnViewMP 1.6.2 x64
BloodyRain2k wrote:So to be clear about it, it was still generating thumbs and I went to an image that was already thumbed and tried to categorize it and bam, it crashed. And that every time. Took me a while to notice what when wrong there because obviously after the thumbing is finished categorizing works fine.
And you are able to reproduce it?
BloodyRain2k
Now after I reported it does it not happen anymore -.-'' so, no : (
It's probably more related to the bug where going into fullscreen view assigns set categories to the wrong image.
http://newsgroup.xnview.com/viewtopic.php?f=62&t=28877
I just had it crash now when trying to set some categories to an image and it was the last image in the folder and when switched to the previous one to apply the set categories is crashed instead, so nothing related to still generating thumbs in that case.
m.Th.
Post by m.Th. »
xnview wrote:I'm not able to reproduce it :(
Yes, but in what state?
Perhaps a dangling pointer is somewhere left out?
I have XnView MP set to read the Embedded Thumbnail from the RAW files.
m. Th.
m.Th.
Post by m.Th. »
I do.
In 100% of cases. :) ...do you want to send you a package consisting of:
1. Two RAW (Cr2) photos.
2. The best(*) tool to generate the many files / folder structure needed
3. Instructions on how to reproduce it
(*) Yes, I'm biased. I wrote the tool. :D
...but don't try to crash it! You'll succeed! :)
m. Th.
Bug confirmed and will be fixed. See issue Issue 150 for current status and details.
