How to migrate ipt to iptc files ?
Infernoweb
Post by Infernoweb »
Hi folks !
I definitively adopted XnViewMP instead of classic XnView software. :D
Now I'm looking for something that could be great : Import classic XnView *.ipt files into XnViewMP (which uses XML *.iptc files). Because I saved a different IPTC data in a lot of *.ipt files and I would be glad to not loose them :wink:
Is there a way to do this ?
Thank you beforehand.
Regards,
Eric
Re: How to migrate ipt to iptc files ?
Where do you use ipt files?
Infernoweb
Hi Pierre,
I used ipt files in classic XnView software on saving IPTC data template from a photo:
- On one photo selected > CTRL+I
- Save template ou Load template
Saving template generates an ipt files with all IPTC data saved like dates, keywords, and so on...
Regards,
Eric
Oh right, the iptc template! Ok, i'll something for that...
