Option 'Source folder' missing
Cobra
Just downloaded XnConvert from the Mac App Store. Works great and has further improved my workflow not having to open XnView just to get to the converter. Only question I have is, what happened to the "Source folder" option under Output? It is nowhere to be found in the App Store version.
Re: Source folder
The version on Apple Store is sandboxed, so i can't access easily folder. You can download the version from my website...
Cobra
Re: Option 'Source folder' missing
Thank you for the suggestion and the speed of your reply.
