When 'Same as image' ratio is in effect, <TAB> will correctly swap height and width.
But after lossless rotate, <TAB> will only swap height and width once. After this, <TAB> shrinks the size of the selection window.
Fixed. v.1.80.2RC
[Fixed]Swap height & width malfunctions after lossless r
Re: Swap height & width malfunctions after lossless rota
I can confirm that part but not the second part of it.marsh wrote:When 'Same as image' ratio is in effect, <TAB> will correctly swap height and width.
Yes, me toockit wrote:I can confirm that part but not the second part of it.marsh wrote:When 'Same as image' ratio is in effect, <TAB> will correctly swap height and width.
