Hello!
First recording of IPTC and XMP metadata in a single JPEG file request up to one second, which is quite satisfying.
Registration of IPTC and XMP metadata in several JPEG is also quite fast (# two files per second on my computer).
At the opposite, a new tag of a file (only a single) in the same directory needs between 3 et 60 seconds to record in file! (screen freeze of program, and sometimes XnView crashes).
Pierre si vous pouviez améliorer ceci ce serait sympa.
PS 1 Xnview MP 0.61 W7 64
PS2 Again thank's for continuous improvement of this nice and efficient program!
Very slow tag (IPTC + XMP) of single file
Re: Very slow tag (IPTC + XMP) of single file
Pourriez vous me donner les etapes pour reproduire?Gérard 91 wrote: At the opposite, a new tag of a file (only a single) in the same directory needs between 3 et 60 seconds to record in file! (screen freeze of program, and sometimes XnView crashes).
Gérard 91
Pierre,
Thank's for interest.
I tag all files of a directory (caption, copyright, keywords, localization).
After I tag some files (caption, keywords)
After I tag only one file (caption) and for that one, recording is always long (more than 3-5 seconds) or very very long (up to one minute when I am not in a hurry and close). Often 15 -30 seconds. Duration seems to depend of operations number before.
When I open Xnview and tag one file, it needs one or two seconds.
I hope this will help to find why !
Sincerly
Gérard
Sincerly
Gérard
Gérard 91
Hi Pierre,
Last days I have continued to tagg few files without noticing slow speed !
This evening, I corrected 20-30 files (IPTC caption ) in 140 files directory. I do notice some slowdown (2-3 seconds to write) but only for the last files.
I know it's not very helpfull!
Sincerly
Gérard
Sincerly
Gérard
Gérard 91
Yes only JPEG
I'll be away for about three weeks so not able to answer.Sorry!
you have the delay when you press 'Write' button of IPTC dialog?
Gérard 91
Yes,
Long delay seems to be noticeable after many tags of files in the same directory (using same tag for several pictures , correcting the tag for few one et finishing by precisions (small changes) in a single caption field or/and Key word (in "IPTC-IIM updating/creating XMP" mode).
strange, ar you able to reproduce a delay of 10sec??
Gérard 91
At the moment I tag only few files and don't notice a significant slowness.
Next weeks and in November I'll have (I hope so!) thousands pictures (about a hundred per directory) to tag so it 'll probably happen again. If I notice something,independently try to note precisely how it occurs, what the best to do ? To save copy of two db ? Save a copy of .ini ?
Any way I won't be able to tell about before half November.
Kind regards
By the way Pierre do you intend one day (not to far)to implement if not too complicated the improvement I suggested herehttp://newsgroup.xnview.com/viewtopic.php?f=60&t=28791 It w'll help me to know
Kind regards
