Thanks
Converting JPEG to .JEF
GiGi
Could someone please help with information on converting a clip art image in JPEG or BMP to JEF for sewing.
Thanks
Thanks
Re: Converting JPEG to .JEF
What is JEF format?
- Forum Librarian
At least for now, XnView doesn't support reading/writing of the Janome Embroidery File format.
digimad (Janome Forums » [url=http://content.janome.com/fusetalk/forum/messageview.cfm?catid=7&threadid=3783#19697]saving to a jef file[/url]) wrote:Gemma, word docs cant be turned into embroidery files, niether can image files, the only thing that will do that is an embroidery digitising program.
If you Google embroidery software you will find various programs, some very bacic some much more sophisticated.
link to economy priced auto digitiser
completely free program
another free program
I'm not going to pretend these are the best programs out there, they aren't but if you try them you might see digitising images or lettering isnt just a case of converting a jpg for a machine.
