I use windows 8 with xnview 2.04
Open a picture
Select Image/Resize
In the "Screen Size" parameter, popup the unit list (% or pixels) and select the same parameter.
BUG: The Width and Height value change
2.04: Image/Resize value change
Re: Image/Resize value change
Thanks for submitting this bug, Gege, which I can confirm.
In my case the values change from 1063x6012 to 11300x361441.
