MakerNotes for RW2 Files
andrewj
Post by andrewj »
If I have a Canon RAW file (.CR2) then XnView displays the full EXIF data including the MakerNotes. However with a Panasonic RAW file (.RW2), XnView only displays a limited subset of the EXIF data, although the full data is there if I look with ExifTool or similar. Is this something which could be sorted out?
Thanks
Andrew
Re: MakerNotes for RW2 Files
andrewj
Post by andrewj »
What's the best way to do this, by PM?
andrewj wrote:What's the best way to do this, by PM?
yes or contact at xnview dot com
