Is it possible to re-create thumbnails embedded in EXIF with XnView?
My wish would be to alter the thumbnails (embedded in EXIF) after editing a photo (cropping, changing brightness...) to reflect the changes but keeping the other EXIF data?
Thanks
Is it possible to re-create thumbnails embedded in EXIF ?
patchfree
- Forum Librarian
Re: Is it possible to re-create thumbnails embedded in EXIF
As of now (v2.05), there's only a command for updating/rebuilding/recreating existing embedded Exif thumbnails.
- Edit » Metadata » Recreate EXIF thumbnail
- embedded thumbnail rewrite
- Embedded Exif-Thumbnails, please a little more ...
- Re: Embedded Thumbnail Not Shown
- ExifTool & Thumbnail
EricvZ (Photozo Digital Photography Forums » [url=http://www.photozo.com/forum/knowledge-base/512-exifer-copy-exif-data-make-thumbnail.html#post4568]Exifer: copy exif-data and make a thumbnail.[/url]) wrote:Brief explanation on the program Exifer (version 2.1.5), for copying Exif-data and making a thumbnail.
Program and info can be found here: http://www.exifer.friedemann.info/
If you want to copy Exif-data:
If you want to create a thumbnail for your pic:
- Start the program Exifer, the screen is devided into 4 areas.
- Left upper is the 'browser'-part, goto the directory where your pics are and select (click once on it) one of them without the exif-data.
- Right upper screen got 4 tabs, selcect the tab 'Exif-data' to view the exif-data, with the selected pic it should be empty, screen says 'NO DATA'.
- Goto the menu-bar on top of your screen, select Exif/IPTC -> Insert from File.
- A new browser window will open and in that, select the picture where you want to copy the Exif-data from, then click on the Open-button.
- The Exif-data will be copied then, no need to save your pic for that.
- Goto the menu-bar on top of your screen, select Exif/IPTC -> Thumbnail -> Create Thumbnail.
- Thumbnail created, if it went right you can see that in left-upper browser window, no need to save your pic.
patchfree
