Brightness and gamma control in XnView 2.05
GrahamM
Post by GrahamM »
When looking at HDRIs, many images can be unrecognisable without adjusting brightness/gamma.
Is it possible to change brightness/gamma in the thumbnail tab view in XnViewer?
I’ve tried playing with Options > Browser > Thumbnails > Use Gamma correction,
to find a gamma level that better suits most of my HDRI’s but this setting doesn’t seem to affect the thumbnails or previews (even tried removing thumbnail cache)
Thanks
Graham
Re: Brightness and gamma control in XnView 2.05
Hmm, I just tried with XnView 2.00 and it worked fine.
I've set gamma value in Options > Browser > Thumbnails > Use Gamma correction and then used View > Rebuild thumbnails to rebuild all the thumbnails in the current folder.
GrahamM
Post by GrahamM »
Thanks Helmut,
It seems to be working now!
Rebuilding thumbnails does the trick!!
Cheers
Graham
