Thank you very nuch,
Multithread support
mdalacu
Multithread support
Hi, can you make this ap a multithread one? I have 6 cores and only 1 is working when i preocess 2000 photos ,,,
Re: Multithread support
currently i use multi core for process, not to convert more than 1 file in the same time
mdalacu
Ok, but on my machine only one core max out. All others are idling. Is this the normal behavior? I don't hink that the HDD is the bottleneck for this situation.
which actions do you use?
Strange resize must use all coresmdalacu wrote:Just resize.
mdalacu
I run it on Ubuntu 13.10 x64 with AMD Phenom x6 1090T.
Oh ok, only supported on windows currentlymdalacu wrote:I run it on Ubuntu 13.10 x64 with AMD Phenom x6 1090T.
Hyper
Sorry for reviving a little old topic, but I have the exact same request. Would you consider adding one file per core converting mode? I found that the current parellelization is quite inefficient. My CPU usage float around 37% when doing BMP->PNG convertion. It's much faster to open four instances and manually seperated the files to four sets. The CPU utilization will reach 100% that way. So I think there are benefits to converting more than one file at a time instead.
Only converting, no action?Hyper wrote:Sorry for reviving a little old topic, but I have the exact same request. Would you consider adding one file per core converting mode? I found that the current parellelization is quite inefficient. My CPU usage float around 37% when doing BMP->PNG convertion. It's much faster to open four instances and manually seperated the files to four sets. The CPU utilization will reach 100% that way. So I think there are benefits to converting more than one file at a time instead.
Hyper
Yes. Converting only.xnview wrote:Only converting, no action?
ok, in this case multi core is not used...Hyper wrote:Yes. Converting only.xnview wrote:Only converting, no action?
Hyper
xnview wrote:ok, in this case multi core is not used...
CreativeWorld
that works for me.xnview wrote:Strange resize must use all coresmdalacu wrote:Just resize.
mdalacu
On Ubuntu x64 ?!CreativeWorld wrote:that works for me.xnview wrote:Strange resize must use all coresmdalacu wrote:Just resize.
