Batch processing - Paste logo
colo
Post by colo »
Hi there,
It seems that we cannot easily paste a picture into another then move it.
(cf. problem still pending from 2012 http://newsgroup.xnview.com/viewtopic.php?f=35&t=24885)
Now I have several photos where I would like to paste a logo in the lower right corner. Is it be possible to automate and batch process this ?
I would already be happy, if I have an answer to the question above, but additionnaly:
- Is there anyway to paste a text as watermark (with transparency, size and orientation) and batch it ?
- if xnview can't, any program that can ?
Thanks ;-)
C
Re: Batch processing - Paste logo
colo wrote:I have several photos where I would like to paste a logo in the lower right corner. Is it be possible to automate and batch process this ?
Have you looked at XnView Tools > Batch Processing... Transformations -- Image -- Watermark ?
colo wrote:Is there anyway to paste a text as watermark (with transparency, size and orientation) and batch it ?
Have you looked at XnView Tools > Batch Processing... Transformations -- Image -- Add Text ?
I haven't used either but could they be the answer except that for text transparency isn't an option?
