Changing default sizes for resize dialog?
Merijn
Post by Merijn »
Hi!
I discovered that when I want to resize a picture (the Resize dialog, shift-S) I can type the numbers 1 to 8 and this introduces certain default sizes. For example, if I press 1 I get dimensions 160x219, if I press 6 I get 640x877 and if I press 8 I get 800x1097. The numbers seem based on common formats, adjusted for the aspect ratio of my image. So 1 I think is 160x160 but since my image is not square, the height is adjusted.
Is there any way I can change these numbers, for example to have 1 give me 150x150 instead of 160x160?
Re: Changing default sizes for resize dialog?
no sorry
